Help Adblock Android Issue
Lana30
What do you do if you have followed all of the steps until you get to what you see in the image and you have to press the save button, but save button is not available on the ‘localhost’ & ‘2020’ screen. I put 2020 because that was what I saw in the Adblock plus notification icon below proxy port.
"dd-wrt" is custom router firmware AFAIK, usually running on Linksys and Netgear. What are you actually trying to do, run it on your phone?
A friend of mine tried to use it to root his phone and since he knows I am learning as much as I can on Android he asked me, but he got me with this one.
He tried to root his phone using Adblock? Is this https://adblockplus.org/android-install the Adblock you are running? You won't use that to root, but AFAIK this prabably needs root to work, perhaps that's where the confusion came from?
I´m Sorry, I got confused. Please don´t listen to the last thing I said. He was trying to run this app for what it was made for, and got stuck there since he said that the save button was not available. Which I think is weird, why would´t he be able to see the save button?
