Add a password to check voicemail?
Teris
Hi guys. I have two questions re voicemail:
1. I want to add a pause and then my password to the autodial my voicemail. Anyone figure it out?
2. Is there a feature like on the iphone that allows me to listen to the voicemail from one person who left a message rather than going into my voicemail generally?
Thanks very much!
Visual voicemail is the way to go IMHO. I use HulloMail and think its great but depends where you are as to whether its available.
Thanks SUroot. I'll try HulloMail. Any idea how to add the pause and password for voicemail autodial? Thanks again!
When the keypad is up > Symbol > Pause (with default samsung keyboard).
Basically its a comma.
That part I knew, SUroot, but I couldn't figure out where to type it in. Thanks for your help, though!
In case anyone else is looking for this, go to the number pad>menu>call settings>voicemail settings>voicemail number.
