Help Add new system sounds / ring tones?
daldude
Is there a way to add more System Sounds or Ring Tones or what ever you prefer to call them for the Transformer TF700t? The ones it comes with are limited and boring.My old tablet has the Cyanogen Mod 9 on it (it thinks it's a GT-I9100 the Samsung Galaxy S II so it thinks it's a cell phone )and it has a bunch of system sounds and many are cool plus it has all the standard ones except that Tada system sound.
Is there a way to add more system sounds to my Asus TF700t without installing a Mod or rooting it?
Is there a place to download all the Cyanogen Mod 9 system sounds?
Once I find some system sounds how do I add them to my Tablet?
Yes all you have to do is download a cm9 rom and extract the .zip. Open the folder you extracted them do and go to the folder:
Extracted Folder/system/media/audio
You'll find 4 folders that all contain .ogg files. These are the system sounds that you are referring too. I don't know what you want to do with them, though to get them onto the tablet, you can just create a folder call notifications and then drop the audio files you want into that folder. After reboot, your device should see them. If you want to overwrite current system sounds, you will need root though.
