Apps Adding text to a View
ahmadux
I'm trying to add a text element to a view that's been created. I've found some answers online, but haven't been able to tailor them. I'm using the TouchPaint example code. Every-time I run the app with the text element, the app fails. I'm new to Android and would appreciate any help. Thanks!
[HIGH]
@Override protected void onCreate(Bundle savedInstanceState) {
// Create and attach the view that is responsible for painting.
mView = new MyView(this);
setContentView(mView);
mView.requestFocus();
TextView tvX= (TextView)findViewById(R.id.pointSize);
tvX.setText("TestText");
// Restore the fading option if we are being thawed from a
// previously saved state. Note that we are not currently remembering
// the contents of the bitmap.
mFading = savedInstanceState != null ? savedInstanceState.getBoolean("fading", true) : true;
[/HIGH]
View class
[HIGH]
public class MyView extends View {
private static final int FADE_ALPHA = 0x06;
private static final int MAX_FADE_STEPS = 256/FADE_ALPHA + 4;
private Bitmap mBitmap;k
private Canvas mCanvas;
private final Rect mRect = new Rect();
private final Paint mPaint;
private final Paint mFadePaint;
private boolean mCurDown;
private int mCurX;
private int mCurY;
private float mCurPressure;
private float mCurSize;
private int mCurWidth;
private int mFadeSteps = MAX_FADE_STEPS;
public MyView(Context c) {
super(c);
mPaint = new Paint();
mPaint.setAntiAlias(true);
mPaint.setARGB(255, 255, 255, 255);
mFadePaint = new Paint();
mFadePaint.setDither(true);
mFadePaint.setARGB(FADE_ALPHA, 0, 0, 0);
[/HIGH]
XML - Using Relative Layout
[HIGH]
<TextView
android:id="@+id/pointSize"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:text="@string/hello_world"
android:textColor="#FF0000"
android:visibility="visible" />
</RelativeLayout>
[/HIGH]
