Additional phone and battery info
cheggerspop
Folks,
If you press Phone and then enter the code -
*#*#4636#*#* (4636 spells INFO)
you get additional info about your phone and battery, plus you can run a ping test :D
Chegs.
**DISCLAIMER** If you bugger your phone up by altering the settings in the menus provided, then I ain't gonna take responsibility for it ;)
Genius Cheggers, what does all the information mean???
Some of the stuff, I don't recognise....:confused:
Hmm, I'm not going to change it but my Orange Hero with the latest Modaco Rom has WCDMA set as the preferred network....
I wonder why? :confused:
Good post cheggerspop!
3G is a type of CDMA known as WCDMA. CDMA just stands for Code Division Multiple Access. the W is Wideband I think. It's not the same as the CDMA used on the likes of Sprint in the US. It's a similar but incompatible technology.
GSM on the other hand uses TDMA - Time Division Multiple Access.
