I have Sony Xperia M4 aqua and I was wondering if there is a way to choose which volume to adjust without having to go to the settings.
When I press the increase button while the music player is open for example, I can't access the notification volume without going to settings, I find it very annoying and I found on different phones a screen which enables the user to change between the different volume settings by increasing or decreasing the volume but I am not sure if that's only available on android 6
Thank you
Thank you
