Help Admire not reading SD card...Any suggestions?
dinomosin
Most of the time my admire won't recognize the SD card (that came with it) I have inside as being there. It will get stuck in Media Scanner running for a long time or just give up. Has anyone else had this problem? Any suggestions to fix it other than the "pull it out, put it back in?"
Back up your SD card to a PC and try formatting the SD card. That may help.
That's weird. The SD Card I got with my phone wasn't write protected and even worked in four other phones I tried it in. Are you trying to format it on your phone or computer? If on your phone make sure the SD Card is UNMOUNTED.
