Help Admire Problem! Help!
Hey all,
My Admire has started to act all wonky. It's been shutting down on its own for awhile now, but never thought anything of it. But now it's gotten to the point where it does it constantly. Also, my power button doesn't really work, it won't lock the phone. And then there's the issue of the home button... I press it.. it gives me the option to Power off, airplane mode, or silent mode. Oh! And one more freaking thing... the battery is just getting eaten up.
I hadn't done/changed anything to it other than I reformatted it about a month ago.
I'm really lost as to what's going on and I'm not that technical. Please help!
Hello and welcome to android forums.
Id try a factory reset. Or possibly root and install a custom rom..
Same thing happened to my friend. There is no way to fix that problem. it means the phone is defunctioned from an unknown cause. My best solution is to get a new different phone. Like the LG Motion 4G, or anyother phone that isn't related to the Admire.
