Help Admire problem?
Hello! I had a soft brick, and then I fixed it with a stock ROM and Odin, but when I did fix it, what happened is, when it pops up RCH-720, there's a yellow triangle with an exclamation point, and when I use CWM it has a buncha recovery errors, then what ends up happening when I flash a new ROM it still says it's the stock rom. Even though I flashed Killahbee, and Admired Monster, and the rom with AROMA. Can anyone tell me what's going on and how to fix it?
P.S; My apologies if this error has been posted already, I did check the auto-suggestions, and didn't find it.
The yellow triangle at the boot screen just says that you have a custom binary installed( I'm assuming it's referring to the kernel or something) so that's nothing to worry about since a lot of roms have this. Also if they're cache errors you're getting you just have to reflash whatever rom you're or you can flash the updated 5.0.2.8 that doesn't have cache errors.
Okay, guys, I'm still having a problem, now I can actually read the errors since 5.0.2.8 has a better font, but I flashed AWO and it still says I'm on stock, but the errors are saying it can't mount the command, or log, can't open the recovery log, or mount the last_log or even open the last_log.
Make sure you wipe /system before flashing....
In CWM, goto mounts and storage, and select "format /system". Then press back until you are at the main menu, then flash :)
I figured. I tried that and then flashed your AWO, now it's just sitting there with the word samsung blinking on my screen, so I'll wait until it's done. If it doesn't work, then what do I do? Let's say it does flash, but it still says it's stock?
You flashed the Admire EXT4 version, right?
If its still stock, then boot back into cwm and mount /system and /data, then reflash....
And if it still is stock, then give it a cookie and ask it pretty please :p
*MUAH* I did it! thanks for your patience and help. I didn't even have to give it my cookies. I sat there and ate them in front of it's face until it gave in. Little red EFFer knew there were worse things in store for him, if he didn't start acting right!
