Adobe Flash Player problem
spotty123
I'm running android 2.1 Eclair, with an ArmV6 Processor. (Freq. 580 Mhz. if that's important) and i cant seem to be able to install adobe flash player armv6 compatible... someone know where i could get one that works on my phone? (if it exists ofc :P)
2.1 doesn't support flash unfortunately. The best I can suggest is to hassle your carrier for an update to froyo.
As far as I know your guess is right on the money: Flash for Android requires ARMv7 instructions... I'm in the same boat with my puny P500 :)
There are some browsers that process the page content server-side so you can view flash stuff that way sometimes. I think one of the opera browsers does this.
SkyFire is supposed to do well at this... at least when it comes to video. Out of curiosity: Why would you want Flash? Like you said, your processor is not exactly high-end and Flash... well, there's no sugarcoating it .... is bloated as hell. Flash5-level files might be possible, but anything beyond that would very likely result in a slideshow for reasonably complex files.
