Help Adobe flash player question
ben1802
Hi guys ive literally just purchased my galaxy 10.1 and im trying to get adobe flash player, however I cant find it in the play store and when I go to adobe website it says that adobe flash player is not supported by this device. I have also installed firefox and having same problem still any help would be greatly appreciated.
Just to add that you need to have an Android browser that supports Flash as well. The stock one supports it. Chrome does not. Firefox Flash support is not enabled by default. You need to check the browser you are using to make sure it has Flash support (or continues to provide Flash support).
Also Adobe dropped Flash support for Android. So don't expect any future versions either.
Here's the official archive files directly from Adobe's site:
http://download.macromedia.com/pub/...roid/11.1.115.54/install_flash_player_ics.apk
The latest version is 11.1.115.54 for devices running ICS.
I've also found it useful to install the Phony add-on to Firefox. Without it, some Flash wouldn't play on Web sites. It supposedly fools sites into thinking you aren't using a mobile device.
I've installed the Puffin web browser, works fine with Adobe flash on web sites.
So I didn't need to install the .apk of the Adobe flash plug-in on my Jelly Bean tablet :)
Harry
Harry
Why bother iwth a paidd app when you can have Flash Player for free?
