Okay, so two things:
- If you haven't upgraded to 2.2, you can't download it. You need to be on the latest version of Android in order to use it.
- If you have updated to 2.2, you already have it on your phone. There may be an update in the market, but you should be able to view flash on your phone.
Also, can you give some details? What happens? Are you going to the market, searching for Flash, and downloading it? If so, you don't have to do that. Ever. The stock version is either already on your phone, or if it's not, you can't use it.
Are you going into the market and seeing the Flash has an update? Does it give you an error message?
