Help Adobre Flash Player 11 doesn't work
gary_a
I previously had Iphone, BB, WP7 and I just bought an unlocked Samsung Galaxy SII, and started playing around downloading lots of apps.
Then I wanted to try the famous flash player and for my surprise it didnt work, so i updated to the 11 version, and still nothing.
I'm using the default browser, i go to adobe test page and it appears nothing, all gray, i can't watch youtube videos either (youtube desktop version)
Does anyone have the same problem?
Thanks for the help
have you enabled plug ins in the browser settings?
assuming you have and its still not showing i can only suggest uninstalling and installing it again.
works fine usually.
