wocmultimedia
Hi,
I am a newcomer on Android developer's community, I wish to post in the correct place this time my message.
I used eclipse helios with ADT 10.1 and it worked fine till I updated to ADT12 and sdk tools 12.
The problem is that when I try to edit an xml file, especially the layout.
If I use the autocomplete code with the panel opening with ctrl+space bar and select an option it sets in place but also erase 13 digit onward causing the rest of the code corrupted.
I tried to reinstall both eclipse and adt but nothing.
I also installed Indigo version of eclipse and is the same...does someone have an idea how to fix it? I cannot reinstall ADT 10.1 cause isn't available on android site as well as the sdk tools 10.
Thank you for helping
Angelo
Angelo
