Advanced Browser Settings
raidscsi
If you open the default browser and type the address "about:debug" then press enter it will unlock numerous settings that are hidden. Once you do this it will appear that nothing has happened. Goto Menu>More>Settings and look at all the candy you just found.
Also on the Incredible there is an extra menu option that allows you to control and delete the hidden bookmarks feature.
I don't have the additional settings but when I go into the more section there is a lot more there :)
If i tap to delete capture files it just force closes. How do i know if they deleted?
When I open my default browser, it takes me straight to google. The only place I can enter information is in the google search box. Where do I enter "about:debug"?
