Help Advent Vega operating system
  • Start date Start date
A
Android Question
Guest
Hi all i wonder if somebody could help me i have an old advent vega tablet and did a factory reset to 2.2 but im having trouble getting the browser to work correctly as it keeps saying your browser is not supported so i downloaded dolphin zero browser for android and can search on the net ok but i dont have a bookmarks bar or any way of saving favourites.
Second problem is i cant view youtube videos it says your device is not supported and third id like to be able to install skype if possible ??
Is there a better operating system i can flash from the sd card ?? that will help me resolve my problems ,i have already flashed it back to its original state but im left with the above problems.
thanks for reading julian
Hi Sorry to say but Skype and YouTube are no longer supported by Android 2.2. There may be some ROMS on XDA developers that you could try but I'm unfamiliar with your device so can't give you any guidance. Flashing a custom ROM can brick your device so take care to read everything TWICE. This may allow you to access Skype and YouTube.
http://forum.xda-developers.com/advent-vega/development
