Hi all,
Hopefully someone can give me some advice, and possibly help me troubleshoot.
My step daughter was given an Augen Genbook Model# NBA10800A by her mother last Christmas. It has never worked correctly for her from what I am told. I work on Windows computers, but have never worked on Android. I think it was set up incorrectly or something initially. Perhaps there is a hack if not a fix?
Currently it can't find a wireless network. I have turned off the ethernet, and turned on the wireless, but it doesn't help. I also cannot check the status of the device. I get the error "The application Settings (process com.android.settings) has stopped unexpectedly. Please try again".
Any thoughts?
Thanks a lot,
Igg
**Update on OS**
Model number listed in the about device section says: Android for Livall TCC8902 GENBook (multi-language)
Might help.
Any thoughts?
Thanks a lot,
Igg
**Update on OS**
Might help.
