My Needs (in order of importance)
Wi-Fi Hotspot enabling
Ability to uninstall (or absence of) crapware
Functions like Camera / Voice / GPS / Google Play Store working properly
Stability
Speed
4.0.3 or Higher
My current system:
HTC Rezound
S-off (JuopunutBear Vigor)
Recovery - TWRP v2.5.0.0
[Kernel] [PrimoU] 2013/05/21 HELLBOY
Rom - AOKP-Neo1.8 Linaro
Android 4.0.4
The problem I'm having now is that the default camera is all weird - it's sideways and no matter how you rotate it's screwed up.
Also phone calls have a weird tin-can sound, and tapping on the case during a call makes it sound like you're beating on the can. Maybe it's not software causing this - perhaps a short from frequently taking the case off?
In recovery, I get "Unable to mount '/emmc' and and "Unable to mount internal storage." errors. Also in when booted up it tells me the SD card is blank, but I can play music and browse files there, so I dunno.
I had no idea about this rooting stuff until yesterday, but I think I might be happy with stock or a close to stock rom with the ability to do what I said above.
Many thanks to anyone offering advice!
Stability
Speed
4.0.3 or Higher
My current system:
HTC Rezound
Android 4.0.4
