HI,
I am trying to interface the UVC Camera to the Samsung Galaxy Tab 10.1(GT-7510) , but I am not able to see the device node getting created in the shell( I have installed the Linux terminal Shell Application) and rooted the device using this Video .Can somebody plz tell/advice how I can achieve it and access the device Node or at-least get it created.
Following is the log on dmesg :
usb 1-1 new high speed USB device using tegra-ehci and address 97
hub 1-0:1.0 unable to enumerate USB device on port 1 ,
usb 1-1:device v0ac8 p3420 is not supported
On My Laptop I get this output on Dmesg :
[12307.364237] uvcvideo: Found UVC 1.00 device Venus USB2.0 Camera (0ac8:3420)
[12307.366108] input: Venus USB2.0 Camera as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input14
[12308.537059] usbcore: registered new interface driver snd-usb-audio
also i can see the camera getting blinked on connection which proves that it is getting the power-supply and getting connected with the system.
I think there is a support for UVC USB devices in the kernel (not sure) otherwise I am ready with the Kernel For Samsung Tab 10.1 (GT-7500 (Higher Version: GT-7510)) from here .(GT-P7500_MEA_Opensource.zip (requires Login).
Plz assist.
Rgds,
Softy
Plz assist.
Rgds,
Softy
