ADW.Launcher Question
zandroid
With the recent updates, ADW allows for a scrollable, unlimited amount of shortcut buttons on the bottom dock, which also takes away the home icon.. my problem is that I have it set for this scrollable dock, but every time I either unlock my phone, or even come out of an app, the dock goes back to the old one, with two/four AB buttons.
I've emailed the dev but got no response - is anyone else having this problem?
Thanks
Wow, I had gone thru all the settings and couldn't get it right - that seems to have done it, thanks!
Mods - You can lock or delete this thread.
Take that back - while your solution helped for awhile, it just won't stay on the new side scroll dock.
No issues yet - trying to open and close apps to see, but nothing. Will post back if anything happens. thanks
After a restart, it went back to the regular dock. I then switched it to the new one, but it still won't stay. I guess I'll wait for an update..
First check to see if you have 2 versions of ADW installed.. if so, then delete one or both and flash the ADW 0.90 system file. Might be an easier way but I've done it and it takes about a minute to put my widgets and icons back. Do whatever works best for you. You can flash Dr. Cloverdale's system ADW (use MDPI if you have a small screen Magic or Dream), use HDPI for larger displays: EVO, DROID. Good luck and remember these steps are dependent on ROOT!
Index of /dr_cloverdale
Yeah I'm not rooted, and the problem was annoying. Was only running one ADW and nothing else. Uninstalled, and have found LauncherPro to be much more stable, fast, and even the scrollable dock works better. Thanks, though.
Thanks
Whats up what version of ADW has scrollable dock. I was looking for it for while when I flashed CM7 EX with the newest ADW launcher and Iam coming from my sense rom with Launcher Pro the most amazing thing about it. And I know about the hiden dock that what I have it set to now but need a scrollable dock.
