Help ADW Launcher won't work
darthlinux
I have Sony Ericsson Xperia X10, I downloaded ADW Launcher, when it had installed it wouldn't let me click open it was just greyed out, I am pretty sure it will work on Android 1.6.
Any idea's?
Any idea's?
adw is a launcher and not a program, press you home key and then you can click on use as std and those adw
Glad you are sorted, this info for anyone else who picks up on this thread with similar problems (bit late for you darthlinux, sorry!)
There is a nice little app called Home switcher that lets you choose your launcher and set/change the default too. So what ever one you are in you can find the others and switch over quickly.
It was great for me cos I was a bit worried about installing ADW then not liking it and not being able to 'find' the stock one again.
i too use the idriod theme (like the wallpaper,) but i mix it with the inverted theme, love the way the icons look against the idroid wallpaper
