Proprietary 40-pin connector. It might be a while before you can find them from anywhere else besides Asus.
I was worried about charging- the cable is WAAAY too short. I even tried using a USB Extension cord, but it doesn't show that it's charging.
With the keyboard I only charge at night. Never have needed to plug it in while using it throughout the day.
it wasn't showing that it was charging probably because you have a USB 2.0/1.1 extension cable. you need a USB 3.0 extension cable for this to work.
You can buy a 3.0 usb extension for about $3. A lot cheaper than buying a dedeicated cable and you can buy it today. I have one and it works.
yerp, but besides the point of getting an extension lead for the usb cable, what "I" want is a spare cable to keep at work as backup. extension cables no use to me if i forget the darn thing lol
Honestly at night I just plug the dock into the power, put the tablet into the keyboard, and shut it down.
I know you're not supposed to do that for the greatest battery life but oh well..
wait, is there a best way of charging here? I always hammer the dock to 3%, then let my tablet run to around the 5% mark then charge both whilst docked. are you saying this is bad for the battery?
You have to use a usb 3 cable if you want to charge utilizing a usb cable.The ASUS manual says that the tf will charge (slowly) if connected to a computer USB port. Is this also true if I plug the cable into a USB wall charger. I have one here that supplies 500ma for 4 USB ports and apparently can supply 2A to one port. I tried it and no charging indication on the tf.
Also, assuming that if the tf can be slower charged when plugged into a regular USB port, how do you know it is being charged?
