mcluskyisms
Hi,
I have just got a Galaxy Note N-7000, its my first Android. I must say I fairly impressed with it up to now although there's a few nagging issues I'm experiencing.
Since I've updated to ICS (4.0.3) I've noticed the handset reboots itself from time to time, usually when its in my pocket (maybe 4-5 times a day). Has anyone else experienced this or got any ideas on how to sort that out?
Also, I cant receive MMS to the handset. Instead a I get a prompt to download it which often fails, I have found I can save the images on the MMS and then go and look at them in the gallery, although I'm fairly sure I'm losing whatever audio that maybe attached to them. I've read something about MMS will not download onto a handset when WiFi is enabled although I've tried turning the WiFi off (leaving data on) and checking again but it still doesn't work?
Lastly, when I try to back my device up with Samsung Kies the back up runs all the way till the end then Kies crashes. I've contacted Samsung over this issue and they mentioned about uninstalling the Samsung drivers and re-installing them although that hasn't resolved it it. I even thought about rooting so I can get that app where you can run a full back up although after only having the handset for a month and not having any greater reason to root than that I've held off.
Cheers,
Chris
Cheers,
Chris
