Help After attempt to unroot, phone unresponsive, screen not turning on
cheg
After trying to unroot my phone, the screen went dark and nothing comes on anymore, even when trying to put it in recovery mode.
Am I dealing with a dead phone now? When I press the vol down and power button I hear the 'usb being unplugged' sound and right after a rapid fire sequence of 'usb being plugged' sounds.
That's all the info I can give you other than I was trying to use Odin. I mistakenly selected the wrong items before pressing start. I got a 'FAIL' the first time then it seemed to have gone right the second time but that wasn't the case.
I think I'm SOL unless someone has a cure out there?
TIA
I can't help, but have you tried the S2 t-mobile forum? They've got a sub forum for rooting and are really helpful. The S2X is essentially the same as the t-mobile version.
