Help After free LauncherPro update Call Problems
seoul1881
Has anyone recently updated their free version of LauncherPro on the optimus v? I recently did so and now all my calls are being lost. The phone seems glitchy. Anyone else using this program and having issues? Any advice would be appreciated. Thanks :)
Could be coincidence. I haven't had any issue with the latest update. If you suspect Launcher pro, try uninstalling it (backup your settings first). Even if that clears up the issue, try re installing LP . I've seen updates install ok, but not function properly. removing the program and re installing it has always fixed the problem. Good luck!
I'm using launcher pro and sometimes it seems like it needs a second or two to catch up to what my phone is doing (on unlock) other than that I don't notice any issues. It used to fc before, but I think the update fixed that
