Apps after i make drawer menu and floating button why my maps can't get my location and location button n
eggys
after i make drawer menu and floating button why my maps can't get my location and location button not show, and why the search place button when it clicked so that force stop? before i add drawer menu and floating button, it's all okay..
picture before adding
de0703481067002
picture after adding
7b79bf481067352
activity_main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<android.support.v4.widget.DrawerLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    tools:context="com.emergency.MainActivity"
    android:layout_height="match_parent"
    android:id="@+id/drawerLayout">
    <LinearLayout
        android:orientation="vertical">
        <android.support.design.widget.AppBarLayout
            android:layout_height="wrap_content"
            android:fitsSystemWindows="true">
            <android.support.v7.widget.Toolbar
                android:orientation="horizontal"
                android:id="@+id/toolbar">
            </android.support.v7.widget.Toolbar>
        </android.support.design.widget.AppBarLayout>
        <RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
            xmlns:fab="http://schemas.android.com/apk/res-auto"
            android:background="@color/background"
            android:layout_height="match_parent">
            <include layout="@layout/activity_maps"/>
            <com.getbase.floatingactionbutton.FloatingActionsMenu
                android:id="@+id/multiple_actions"
                android:layout_width="wrap_content"
                android:layout_alignParentBottom="true"
                android:layout_alignParentRight="true"
                android:layout_alignParentEnd="true"
                fab:fab_addButtonColorNormal="@color/white"
                fab:fab_addButtonColorPressed="@color/white_pressed"
                fab:fab_addButtonPlusIconColor="@color/half_black"
                fab:fab_labelStyle="@style/menu_labels_style"
                android:layout_marginBottom="50dp"
                android:layout_marginRight="16dp"
                android:layout_marginEnd="16dp">
                <com.getbase.floatingactionbutton.FloatingActionButton
                    android:id="@+id/action_a"
                    fab:fab_colorNormal="@color/white"
                    fab:fab_title="Tambal Ban"
                    fab:fab_colorPressed="@color/white_pressed"
                    fab:fab_size="mini"/>
                    android:id="@+id/action_b"
                    fab:fab_title="ATM"
                    android:id="@+id/action_c"
                    fab:fab_title="WC Umum"
            </com.getbase.floatingactionbutton.FloatingActionsMenu>
        </RelativeLayout>
    </LinearLayout>
    <android.support.design.widget.NavigationView
        android:id="@+id/navigationView"
        android:layout_width="280dp"
        app:headerLayout="@layout/header_menu"
        app:menu="@menu/menu_navigasi"
        android:layout_gravity="start">
        <!--perintah buat nampilin menu utama kemudian bisa di slide yang ada menu adalah yang layout_gravity-->
    </android.support.design.widget.NavigationView >
</android.support.v4.widget.DrawerLayout>
activity_maps.xml
Code:
<RelativeLayout
    <LinearLayout
        android:id="@+id/header_tempat"
        <fragment
        android:id="@+id/map"
        android:name="com.google.android.gms.maps.SupportMapFragment"
        tools:context="com.emergency.MapsActivity" />
    </LinearLayout>
    <Button
        android:id="@+id/Bsearch"
        android:background="#ff4081"
        android:src="@android:drawable/ic_dialog_map"
        android:text="Search Place"
        android:textColor="#fff"
        android:onClick="onSearch"
</RelativeLayout>
