Help After Lollipop note 4 notification sound issue?
Blue218
I just installed the 5.01 Lollipop update on my Verizon Note 4. After the update the Notification sound is the default sound, the whistle. I have changed it to another sound on my SD card and it plays fine, but when the notification comes in it still plays the whistle tone. Any ideas? I have tried changing it in the sounds/notifications menu and it did not take. I have also verified the tone is available on the SD card in a folder called Notifications and is playable. I have done a factory reset and it still is stuck on the whistle as the default notification.
What is activating the notification? Texts, another APP? Look inside the setting of the App that is not behaving like you want to see if the notification settings are set to something other than default.
Good Luck!
Ron
Thanks for the thought....but all the apps (gmail and [non verizon] stock messaging app are set to default notification, which is set to a music (mp3) notification but the whistle plays. So I checked and no dice....any other ideas? Bug?
Been chasing this a few days myself . I thought I had it fixed using a fix I'd read that said you go to the SD card and change the folders like "Notifications" to "notifications" etc etc as people said Lollipop doesn't like the capital letter in the files structure.
That worked a day and reverted back it seems, I might have rebooted not sure. Then.... I switched anything that was set to "default" to whatever I actually wanted it to be (just not using "default", even though it already showed the default as being what I wanted and even played what it was supposed to be when I played it, BUT when an actual notification came it whistled.... Ugh... It seems to be working. Trying that for now and we'll see. Using the 'whistle" this seems to be a repeatable issue that people are having. Mostly regarding the system default notification and Google mail..... It was doing it to K9 mail but stopped... Ugh...
