Root After NAND restore my phone keeps powering down
Whip
I have just done a nand backup, then unrooted (downgrade), then used Unrevoked to root and did a nand restore.
Btw that took forever! Anyway after it was said and done the phone rebooted, and viola everything was back on there. The only hitch is since I have done the restore my phone has shut off by itself 3 times. I was ever so reluctant about doing the whole Unrevoked process and this is why. Has anyone else experienced similar issues? Please help!
Update: It hasn't turned off since after the third time so I guess it's stable now.
what was the point to unroot your phone then root again? if you did it to install the OTA then restoring the NAND that was before OTA will cause problems on a after OTA phone
