After trying to fixing brick phone
I just brick y91i after trying to root but it seem that I brick but I install stock room after reaching at setting your phone option but there is no touch response all physical button are working but there is phone exception error please help me?
Are you sure you installed the correct ROM for your particular model and variant of the Vivo phone? It could be the ROM works, but maybe the kernel drivers are incompatible with this phone's touch-screen hardware? But as I don't know what variant you have and what ROM you installed, I don't think I can help you much more.
Vivo y91i stuck at fastmode boot whenever I restart phone I think this is loop help me this was happen after flashing stock rom
i'm not sure i understand this. so you flashed the stock rom? where did you get it? try the firmware i linked earlier. the firmware is the stock rom.....just make sure the firmware is for your specific device. firmware is very device specific.
I appreciate your help and thanks it work and my device is saved I'm currently message this on unbricked phone you saved me for wasting 100$ for that phone...
oh nice!!!!!!!!!!!!!!!so that firmware i linked worked for you? just so you know this is what we call soft bricked. if you truly bricked your phone, you might as well throw your device away. there are no fixes for phones that are truly bricked.;)
there's not much info on your phone. i always look at xda.com as my main source for rooting phones. i also look to see if there is any developers support for any phone. for me no dev support=no fun. no dev support also equals no custom recovery or custom roms. this is the only reason i would ever want to root a phone.....especially having a custom recovery....that is key.
a custom recovery lets you make a complete backup of your phone called a nandroid backup....among other things recovery can do. i would not want to mess around deleting or flashing things unless i have a recovery.
and there really is not anything on xda save for this thread:https://forum.xda-developers.com/general/rooting-roms/how-to-unlock-bootloader-vivo-phones-t3686690
but i do not know if it applies to your phone or not.....sorry but you might be sol on rooting your phone.....next time pick a better phone that has support for rooting.....like a pixel phone.
How can I fix imei issue after flashing stock rom
not sure, can you be more specific? whats wrong with your imei?
When I unblock vivo 1820 then when I insert SIM only one is working and a popup shows where it show your IMEI OR meid no. Is invalid but I used ussd code the both IMEI NO. Were same though only one can work
unblock? do you mean unlock? your phone should only have one imei number....so i'm not sure what you mean by "both IMEI NO." so only one sim card is working? have you talked to your provider? i would do so if you have not.
If this phone has been blacklisted, flashing a ROM or switching SIM cards won't matter. Again, the IMEI is a phone identifier and its on a hardware level. The IMEI is tied to the phone itself, neither the version of Android its running nor the SIM have any relevance to the IMEI.
Check the IMEI on its status:
https://imei24.com/blacklist_check/
Yeah i have one imei but it show for both sim1 and sim2 but only 1 sim is registered and its working .. Unblock or unbrick
No i have flashed my stock rom and i faced the problem of invalid imei and mied.
