Agat Recovery: Huge problem help ASAP!!
I deleted everything on my phone by mistake and the CWM Recovery backup is the wrong one! I can't even boot my phone normally! If someone has an AGAT formatted Factory Reset Recovery, please post! Desperate here!!
Do you have a PC? Just go to the repository and download the one click install for the stock ROM and put your phone in download mode and flash it.
Try a factory wipe, If that fails, flash the ROM again. Note: don't use a usb 3.0 port if your PC has them, others have had problems with those. You may want to re download the file. I did the One click several times as I hopped from leaked JB to Leaked JB until we had the official release.
The other option it to do it with the tar file and PC Odin (more annoying, but works and can take you back to ICS if needed)
this is sort of off topic from the op but the title fits lol so here we go.
anyone know where i might find a very specific recovery kernel for the s2 on jellybean. the kernel is sxtp agat gc01. i used to have it but recently soft bricked so i had to use the one click. i cant find it anywhere except sxtpdevelopers but that appears to be a dead site now. i havent found another recovery kernel that works on gc01 which sucks cuz im pretty sure ive tried everything short of doing the ics one click and then using the fl24 recovery from rwilco
Edit: I ended up using the one click and fl24 kernel just cuz I can't stand not having a "real" recovery lol
