Agfaphoto tablet
yuvalgls
hey guys, whats up?
i got a agfaphoto for a gift from some site... you know the saying there are no free gifts? the phone worked for 2 weeks and someday got stuck on the flashing android logo on boot.
i had looked and searched the web but i didn't find nothing on this tablet and the vol - power button combo does nothing.
do you know any way i can get it running again?
tnx yuval
First off welcome to the forums :)
Unfortunately i don't know anything about that device or have even heard about it.
These are the dangers of having off brand devices...there isn't really any Dev support and no one really can try and help you get through it.
If anything i would suggest to just perform a factory reset and see if that fixes it. :)
do you know how to do a factory reset?
Most likely it can be done by booting into recovery, this can be done by holding Sound Up/Down and then the Power Button.
From their you should be able to factory reset it.
EDIT: I notice you said earlier about it doing nothing, but just be patient and be sure to hit the Sound up/down then the power button.
