AGM Rock V5
Phil73
Hi all not long since bought a agm rock and am interested in rooting it but am a complete newb I was going to use root android but from what I have read on here defo giving that a miss (cheers for saving me 30quid) any ideas any body?cant see anything on the phone lists apart from the cat b10 which is the same phone but i dont know if the firmware etc is the same any help much appreciated :confused:
To Root CAT B10 or its associates, FortisX, Utano Barrier, Telex 3200R, etc.
go to Utano Barrier T180: Root Zugriff einrichten - Seite 3 - Android-Hilfe.de and download the update zip (you might have to register...use google crome as it provides a good translation). place the zip in the root of your sd. reboot into recovery and install zip from sd. reboot and your rooted.
found this under AKA utano thank you very much tommytopdrive dead simple and it defo works just done it, shit my self when it came up with android system failed (or summat like that) thanks again gimmie those appps
Welcome to the forums Phil - thanks for the link... I'm sure it'll help out others who want to root this device in future :)
