Apps AHHHHHHH Please help!
matt20687
Hello,
I am working on something that basically does the following:
Opens a splash screen plays a little tune hangs for a couple of seconds and then goes onto a different screen which has two buttons and a little bit of text.
It gets stuck when it tried to go onto the second screen, there are no error messages that i can see. There is one thing on my java code page for this screen that is crashing which says Source Not Found, the source attachment does not contain the source for the Activity.class.
There is a button to change attached source but i havent a clue what to do.
Any ideas?
Sounds like you may have forgotten to add the new activity to the manifest. Go to manifest/Application tab and at the bottom is Application nodes, add the activity there.
If you have done that, then I think you need to show code to help diagnose the problem.
Hello,
I have taken a look and it is in there unfortunately. My .xml code for my manifest is below.
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.cornboyz.thebasics"
android:versionCode="1"
android:versionName="1.0">
<uses-sdk android:minSdkVersion="8" />
<application android:icon="@drawable/icon" android:label="@string/app_name">
<activity android:name=".myMain"
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
<activity android:name=".myMenu"
<intent-filter>
<action android:name="com.cornboyz.thebasics.CLEARSCREEN" />
<category android:name="android.intent.category.DEFAULT" />
</intent-filter>
</activity>
<activity android:name=".tutorialOne"
<intent-filter>
<action android:name="com.cornboyz.thebasics.TUTORIALONE" />
</intent-filter>
</activity>
</application>
</manifest>
______________________________________________________________
MY CODE FOR THE ONE THAT IS CRASHING
package com.cornboyz.thebasics;
import android.app.Activity;
import android.content.Intent;
import android.media.MediaPlayer;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
public class myMenu extends Activity{
MediaPlayer mpButtonClick;
@Override
// TODO Auto-generated method stub
setContentView(R.layout.main);
//set up the button sound
final MediaPlayer mpButtonClick = MediaPlayer.create(this, R.raw.chimes);
Button bTutorial1 = (Button) findViewById(R.id.tutorial1);
bTutorial1.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
startActivity(new Intent("com.cornboyz.thebasics.TUTORIALONE"));
mpButtonClick.start();
Hello,
After looking into this using google it looks as though it is the JAR file that is causing me problem. I have the following error. Can anyone translate this into english?
// Compiled from View.java (version 1.5 : 49.0, no super bit)
public abstract static interface android.view.View$OnClickListener {
// Method descriptor #4 (Landroid/view/View;)V
public abstract void onClick(android.view.View arg0);
Inner classes:
[inner class info: #1 android/view/View$OnClickListener, outer class info: #7 android/view/View
inner name: #9 OnClickListener, accessflags: 1545 public abstract static]
You might have to extend your main class:
might have to be
public class myMenu extends myMain{
I seem to have fiddled too much. I have somehow lost my source folder in the package explorer and my code is now showing error messages. How can i get them back?
