Airplane Mode Running 100%, No Sleep
yesterday i charged my phone to 100%, enable airplane mode and disconnected from the charger, aroung 9:00 pm, just to see if my bad signal was the battery eater. Today, at 7:00 am, my battery was at 70%, so it got worse with the airplane mode, checked my battery info, and on other usage was running 100%, screen like 0.9%, my phone did not go to sleep, this is or a bug on the airplane mode?
now, i disabled airplane mode at that time and now, at 12pm it only used 3% of the battery.
its a new flash, no apps installed, no timescape, gmail, anything.
Do you have a task manager running? Get one like Juice Defender or Mobile Guard by Netqin and then take a look at what else might be using some battery power.
I wold suggest installing one....turn on airplane mode, then take a look at what is running what the airplane mode is running.
I have only used airplane mode a few times, but I haven't noticed any issues with mine.
If you are looking for a longer running x10, I would suggest installing one of the custom images that have even less applications on them.
There are battery saving features on the phone, but I find that some of them don't kick in when the phone has a lot of battery power....like between 100-90 percent if I turn on the wireless I haven't seen it turn that feature off for battery saving....but when the phone is between 50-40 percent the wireless turns itself off within 4-5 minutes of me not using the phone.
