Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
Depending on your device, you should have an air plane mode toggle, let us know what phone you have
Welcome aboard. Thanks for joining the community. ∩__∩
There are two ways of doing so on the device. Hopefully your device works the same way as mine. 1) Press and hold down the power button until a pop-up menu appears - you should see airplane mode tap on it either turn it on or off. 2) Go into settings - wireless & networks and unchecked (✔ the airplane box.
Here's hoping this place will be of great use to you. See ya around.
