Help Alarm Clock Gingerbread
Hi,
I recently updated my SGS to Gingerbread 2.3.3. I'm using my phone as my alarm as well. But it's not working fine, I've been allready to late at work, so this is really annoying me.
The alarm just doesn't get triggered every morning.
When I set my alarm for the first time and save it, it works fine. But the next day it's not working anymore.
When I go back to my alarm and Uncheck / check the green icon it says 'The alarm is set to 5days 7hours... from now' but that's wrong it had to be '22 hours ...' and not '5days...'. When i edit the alarm and click save, than he's telling me 'The alarm is set to 22hours from now'.
Is there anyone who knows what's going on here? I hope someone will.
Thx
Jonas
Hi,
when you select the alarm go into options and select which days you want it for, ie M T W T F S S or M T W T F hpefully that should solve your problem.:D
That's not the problem, I've allready set it for all the days but it's not working. All my settings are correct. The first time I set my alarm it's working, the second time it isn't working anymore. When I check my alarm to see when it will ring (uncheck the green icon and check it again, it's saying your alarm will ring within 5 days from now... But when I open the alarm settings and save it (without changing anything) than it's saying your alarm will ring within 22 hours from now and that's correct.
