Alarm clock only when plugged in
Dan-droid
Member
Anyone know of a way to set up an alarm clock that will be enabled only when my MT slide is plugged in? I often get up before my alarm, and it would be nice if the alarm was disabled when I unplug and re-enabled when I plug back in before bed.
I just did a quick test with Tasker, and it was able to stop the alarm from sounding when the phone was undocked, however the alarm also didn't clear, so it remained set, and I assume would sound again at the appropriate time the following day even though it wasn't set to repeat. I don't know of a way to use Tasker to enable a specific alarm though.
There is also an Alarm Clock profile in the Tasker Wiki that may already do what you want, or may be modifiable to do what you want.
