Help Alarm Clock Problems :(
Hello all,
My alarm clock is playing up, ever since I got the phone it would pick and choose when it does and does not want to go off, a couple times its not went off at all, I dont really want to download an app off Google Play because I dont really like packing my phone with loads of apps. Yesterday I woke up to checm the time during the night and then went back to sleep and my alarm never went off, its really annoying, does anyone know of a way to solve this?
Hello all,
This has never happened on mine. Are you using stamina mode/low battery mode at all? I don't use those and mine has never failed. If you do, I would suggest switching them off and doing some "test alarms". Failing that, factory reset?
