Alarm clock question
Try placing your .mp3 in the /system/media/audio/alarms folder. The default files are .ogg, but .mp3's are supposed to work.
It's always worth a try to restart. Based on jjrx3's response, mp3's should play. You could try making the Alarms folder under sdcard as he did.
I set it up as sdcard\media\audio\alarms but its not working.
The default location for alarms is /system/media/audio/alarms but you need to be rooted to access that location. Since it worked for jjrx3, try his solution of placing them in /sdcard/Alarms
