Help Alarm clock snooze problem
TRaGiK
The snooze on my phone's alarm clock doesn't seem to work. When I swipe to snooze, the alarm stops and leaves the "ZZzzz" next to the time on the alarm, but never goes off at the set snooze time. Am I doing something wrong?
You don't need to swipe to snooze, you need to swipe away from snooze. By swiping towards you are selecting to turn the alarm off.
I think I might have misread that. Snooze isn't active by default so you may have to select the amount of snoozes and times between as you're setting the alarm.
Yeah I did think that as I was writing but I just had to dig a deeper hole for myself:D
Try going to setting, manager applications, all tab, clock and clear data and then reset the alarm.
I am having the same problem with my snooze. I tried to clearing the alarm and resetting. Still doesn't work. I hit snooze and get the Zzzz. But then when snooze should go off there is no sound and the snooze icon changes back to the regular alarm icon.
Alarm Clock Extreme in the market. Go check it out! If you are the kind of guy/gal that hits snooze several times and simply want to reach over without looking at the screen in fear you might turn the alarm off on accident then this is the app for you. Go check it out. There is a free version and paid. Just some advice. In the settings select large snooze button and shake to dismiss. What this does is give the entire screen a snooze button. When you are ready to get up simply shake the phone to turn it off. I looked and looked and finally found this app and it fits my needs perfectly. Go check it out.
I ended up having the same problem again.
Ended up using alarm clock extreme as well. It works great, but I really wish the stock alarm worked as designed...
I have the same snooze problem. I tried all sorts of reboots and cache clearing and nothing seems to work. Very annoying.
After trying the default alarm clock, I went with alarm clock extreme also. having to swipe to snooze is a PITA and easy to mess up. I like alarm clock extreme's big snooze button, plus I like the ability to have the alarm sound volume build up slowly instead of full volume right away. You can customize the amount of time the volume goes from 0-100% in the advanced settings; I set mine to 15 seconds so I'm not blasted awake, but I don't sleep through the alarm either. :)
Also having the same issue...thought I was losing my mind. Have been late to work twice thanks to this engineering genius. This is my first android phone and little sh*t like this is leaving me most unimpressed.
