Alarm Clock
ColinMcF
Are there any good alarm applications for the X10i?
Basically I use my phone as an alarm to get up for work. My old Nokia N96 I could set the alarm and then switch the phone off at night and the alarm would still go off on time. This does not seem to be the case with the X10i. It doesn't even go off when the phones in airplane mode which is poor. I just don't want to have to leave my phone on overnight in case it rings and i wake up.
Are there any good alarm apps that allows you to turn the phone off and the alarm would still ring at 6.30 for work?
Nope. The Alarm clock is running as a process on the operating system. If the phone is off it won't turn on.
If you don't want to be disturbed by the phone rining in the night then you can put it on silent. The alarm clock will still sound in the morning even if the phone is on silent, this is what I do anyway.
Make sur ethat you don't kill the alarm clock application with the task killer. Also make sure that alarm clock is in the ignore list on the task killer just in case it decides to kill the app because it's inactive or something.
Try my app "Alarm Clock PlusV2" it will run while your phone is asleep (not off) and wake the phone for the alarm. The alarm volume is independent of the ringer volume too, so you can mute your ringer and still have the alarm go off. Not to mention it has a ton of other features.
I've had my phone for about 2 weeks now. (x10a)
I've been using Alarm Clock Extreme (Free), so I decided to install yours.
When I launch the app and click on the Music Icon (#3) I get the following error:
The application Alarm Clock Plus v2 (process com.vp.alarmClockPlusDock) has stopped unexpectedly. Please try again.
Any ideas?
At the main screen hit the menu button on you phone, and go to Main settings.
Change the music app to a different app (the x10 probably doesnt have the stock android music player) and see if that works for you.
Under which setting option? manage applications?
I looked for my music app and can't see anything to use change as default.
At the main screen, push the menu button on your phone, then go to Main settings... Then click the option that says "Select Music Player app" and choose which app you would like the music button to operate, or choose "(hide button)" to hide it entirely.
Get Maths Alarm Clock its awesome you have to solve some maths before it stops going off guaranteed to wake you up!
@cvp
I'm interested in trying your alarm program, but I hear that some of these programs get "goofy" if you have the phone plugged in during the night. Will your program run fine if its left plugged in to charge during the night?
(maybe an odd question, but I read some people having problems...)
Thanks
@cvp
Thanks
It will run just fine... There's about 100,000 active users using the app and I've had no emails or comments about any problems with the app and leaving the phone plugged in at night.
I installed this Alarm Clock V2 yesterday. But I have found some issues, that annoy me a lot. Because I live in ****ing Finland, I'm not able to buy software, 'cause the damn Google ain't getting the market working here, which is a shame for all Android owners.
Anyway, the issue. Because it is free, it has all these advertisements loading and when alarm is ringing, I cannot hit snooze from side button. I have chosen the option to snooze from sidebutton. But after I have touched the screen and pulled down that taskbar and lifted up, I can snooze from sidebutton and the same time I also see the advertisement loaded under the snooze button.
Also it is possible after I first hit power button to shut down screen and wake it up again from power button, then I can hit snooze from sidebutton.
It is a nice application, better than the original one.
It is good to have this math to "really" wake up, so that you can't just accidently or by meaning, hit the alarm off. I did hit the alarm off by accident a day ago and also red about this new issue with the original alarm after update, so there was two reasons to find out a new software.
I'm using X10.
I was wondering if anyone knows how to change the alarm clock alert to my own mp3 without downloading an app? The alarm clock that comes standard on the phone is fine with me and i was hoping to be able to do this without downloading a special new app. I have the "ringtone" app which allows you to use your own mp3's for anything else, but can't figure out how do get mp3's to the alarm clock. can someone help me please?
I think it can be done by making a ringtone with for example Ringdroid and using that then. It appears to the list of sounds. At least it should appear, I had them there. I don't use the original alarm, the Alarm Clock V2 is way better :)
Add the mp3 file to a folder on your SD card called "Alarms". These will then show up as a choice when you go to choose the alarm sound. If you dont' already have the "Alarms" folder, just create it first.
Also, if you want to add additional sounds for notifications or ringtones, the same thing applies. Create if necessary and add the sounds to folders called "Notifications" or "Ringtones". These will then show up as new choices.
Hope this helps!
