Alarm problem
I am using modaco 2.2 I think it's called. But my alarms are silent. Everything else such as SMS alerts work fine. Does anybody have any ideas to fix this?when I pick the alert tone it makes no noises also.Many thanks in advance
Hey,
I had a hard time figuring this one out to begin with too, while you are in your alarm screen if you play with your volume control you should she the volume box pop up but it would be marked "alarm" instead of "ringer" or "media"
Hopefully that helps
Hey,
worked a treat, many thanks!
