Help Alarm Problems
f891roy
Member
Soooo, has anyone found an alarm clock app that works when phone is completely off yet??
Been reading about this and it goes back as far as Octber 2008!! WTF is going on. Sony are bound to have a simple fix for this.
All of my sony ericsson phones before (including the satio) had a working alarm clock when i turned my phone off at night time.
I read somewhere that its an android problem not just the X10. No idea if this is true or not. I don't use the alarm overnight but have used it as a reminder during the day and not had any problems.
Or, as an alternative, use the Sweetdreams app to put your phone to bed, then wake it up just before alarm time in the morning.
Sweetdreams:
chart
I'm not sure what you mean. Are you referring to the "Complete" Power Down, as the off you are referring to? Why would you be using the Complete Power Off on a daily basis? It defeats many of the phones abilities... However, when I use the power off option (Also the Time Out option), the alarm works, the phone rings, everything is there ready for you...
I have to ask, just so I understand the problem, why is it important to have the phone off?
If its that you don't want to receive calls/texts/email updates etc through the night why not just put it in airplane mode and then the alarm rings quite happily but your 'phone' is effectively off.
My point exactly... That's is why I asked for clarity as I don't understand the OFF problem....??? Another idea besides airplane mode, Just forward your calls, that way you don't get bothered at night, if your getting that many calls.. Forwarding (To another Number, or Better Yet, Voice Mail, which is what I use) works great to resolve this...
Diections, from the Home Screen: Press the left button and select SETTINGS > Call Settings > GSM Call Settings > Call Forwarding > Call Forwarding Setup as Needed
most of the time i just let my battery run completely dry. So if it dies in in the middle of the night, i dont wake up to switch the charger on...... no alarm...sleep in....:D.....feel very refreshed.
Yes i do like the extra sleep but my boss doesnt. :confused: Need to get a better understanding boss i think :)
