Alarm Sticky Note
saptech
Android Expert
I just recently installed this app, Alarm Sticky Note (Reminder) but for the life of me, I don't see it listed in the Application drawer. It needs to be used as a widget but when I try to add it as one, I can't find it anyplace. Looking in Settings, Applications, show as installed.
I've uninstalled and reinstalled it but still can't find it.
Has anybody tried this app, if so, what are your thoughts?
If you know of another Reminder app please let me know the name to try out.
http://www.androidzoom.com/android_applications/productivity/alarm-sticky-note-reminder_bzbkq.html
I installed it from Google Play.
Thnx.
Some widget only apps don't put an icon in the app drawer. Try adding it as a widget and you should see it in your widget list.
I'm not seeing it in the widget list. I've since unistalled it. If it's this hard to find the widget then I don't need it.
Thnx.
If you are using ICS (and maybe some custom roms or launchers) the widgets show up as a separate tab on the app drawer.
I'm using the version before ICS, is it Gingerbread? I'm using stock, no rooting or custom roms. I am using Go Launcher Ex and I do see the Widget screen to add widgets but I'm not seeing the Alarm app.
justtom, what is it you don't like about the app? Does Colornote offer pop up reminders?
Thnx.
Well it turns out I was looking in the wrong area for the widget. So it is available, but I have not reinstalled it. I went with Colornotes.
