Alarm tones
Create a folder media\ringtone (on your main member for best use) and then put the sound file in it.
from the root create media folder then create subfolder of media called ringtones (plural) I mistakenly had it singular in my post above.
I assume "root" doesn't mean I have to root my phone....?
I already made a folder in the "media" folder, labeled it "ringtones" and copied them in there, and I still can't use them for alarms.
Hey, sorry for not realizing this, maybe they just took a few minutes to show up. I DO HAVE THEM in there now. Thanks for the help!
Once you have the file in the right location you should see them listed in the possible tones Go to settings>sounddevice ringtone and your file should be listed. I am assuming that the tone is an mp3 file. If not I am not sure what other types of music will be allowed
