Help Album Art Missing in My Library?
So I am having an issue where the "My Library" page doesn't display album art for songs I imported from iTunes.
The album art shows when I play the song, but just the generic art shows in the my library which really bothers me.
I tried album art grabber and no luck.
Any ideas???
I would try grabbing a file explorer (like ES File Explorer) and navigating to where your imported your iTunes music and see if there is a file called artwork.jpg in each of the album's respective folders. I think iTunes does something weird with embedding the artwork inside the file itself so other players might not read them correctly as the actual album art.
Are you talking about specifically in Google Music though?
My album art for music physically on the nexus doesn't show, only music uploaded to Google music shows.
I'm having this problem to the album art is on the nexus 7 but it won't show on the my library part on my home screen.
I looked for info on this a while back, as far as I could tell only music that has been uploaded to google play music will show cover art on the homepage widget
music you added to the device will only show a generic cover
