Album Art
guttyla
I use various album art apps to get my album art. After I spend time getting the right covers...minutes, days, weeks later all my album art is messed up. Typically one album covers is shown for about 15% if my covers...very frustrating. Any remedies?
Try replacing the Album Covers using 'Cover Art Downloader' or 'Album Art Grabber'.
You can also try using SDrescan to hopefully fix the cover art.
If you want to delete all your Album Art to delete repeats (if you have too many songs) start over do the following steps:
Go into SETTINGS > APPLICATIONS > MANAGE APPLICATIONS
Select the ALL Tab
Scroll down to MEDIA STORAGE
Select CLEAR DATA
I've had similar problems. It seems that many Artwork Grabbers place the same cover for any track that has "greatest hits" in the album field of the mp3 info tag. Nice example of stupid coding IMHO.
