All Calls Go Straight to Voicemail
Had the phone for about a week and now all my calls have started going direct to voicemail. If I turn the phone off and turn on after a bit all my calls will start going to voicemail. If I place a call then I can receive calls for a while then it will start the voicemail thing all over again. I stopped by Verizon today and they have never heard of the problem but did replace my sim card, worked for a while and now back to the same old thing. I have checked all settings and they are correct. Not on airplane mode, no persons in the refuse call list. Anyone have this problem and if so do you have a fix.
thanks
Jerry
I am with vodafone and could not turn voicemaiI off in settings, i found out i could call 1210 to turn it off, and 1211 to turn it on.
There might be a number to turn yours off permanently.
It happens on many phones including dumb Nokia. Put your sim in another phone. If it continues its a problem with your voicemail service not phone.
Like max said, turning voicemail off and on via your carriers short dial numbers should fix it
