Help Also stuck on fastboot, reboot won't work
New here on the forum, need some help though if ya'll have the time...so my phone went to fastboot to which I didn't do anything to trigger this thing to do it...but that's it...bootloader,reboot, or reboot bootloader dosen't do anything to it....when you do try, it turns off then starts back again to the fast boot menu
this was the display on fastboot
*** LOCKED ***
K2_U PVT SHIP S-ON RL
HBOOT-2.21.0000
OS-3.11.707.101
eMMC-boot 1024MB
Oct 16 2013, 18:25:48.0
thanks in advance :)
hmmm take this to the rooting section but uhh stuck on bootloader ive never heard of and your display looks correct
can you access fastboot usb mode and put in commands.idk why your stuck but im sure it can be figured out
nothing I can press on the menu seems to work though...always comes back the same end
ooh I want in on this one! cuz Im always right! I know its probably solved by now but.... if hes stuck in fastboot doesnt that mean his OS is gone? So wouldnt the answer to be to unlockbootloader--> s-off--->install TWRP --> Add one OS for a bowl of spicy HTC soup?
Edit: after some time to think I decided that I should disclaimer that I am rarely right. Witty sarcasm is not evident in the written word I think
Sorry bro i do not know how to help you, i would like to do it but i have the same proble with my tablet Trio Stealth G4 7. I installed a wrong bootloader and now mi tablet is stocked on the boot logo and also i can not enter to factorie reset.
Can you see your tablet in adb? Maybe adb reboot recovery can get you to the recovery to factory reset> If that doesnt work, then Im out of ideas :)
