Hi there,
I have been using the Motorola Flipout in the last months, and I have an annoying issue to report: quite often, the alt key, and sometimes the shift key too, become "sticky", without warning, causing all keys to execute their "alt" or "shift" action when pressed. Both key should act just once, when pressed; this happens in all applications, but I can't find out what triggers it.
It is very annoying, because this random event is impossible to predict, and can cause, for instance, the deletion of an entire line in a SMS.
Has anyone else experienced this? Do you have any suggestions?
Thanks a lot!
Thanks a lot!
